Need help finding command
actually there are two similar varibles as seen by the output of this command
nvram dump | grep ipv6.*gateway
but the actual command you requested is
nvram get ipv6_gateway
or
nvram set ipv6_gateway=value
or
so when I type the command I receive
size: 77075 bytes (53997 left)
ipv6_gateway=
is this not what I want to see or does it matter?
Dump and show are the same thing.
But show prints an extra line of stats to stderr
ipv6_gateway=
ipv61_gateway=
or just go to town with
nvram dump | grep gateway
dhcp1_gateway_x=
dhcp_gateway_x=
ipv61_gateway=
ipv6_gateway=
lan1_gateway=192.168.2.1
lan_gateway=0.0.0.0
wan0_gateway=24.X.X.X.X
wan0_gateway_x=0.0.0.0
wan0_xgateway=24.X.X.X.X
wan1_gateway=0.0.0.0
wan1_gateway_x=0.0.0.0
wan_gateway=24.X.X.X.X
wan_gateway_x=0.0.0.0
so the X.X.X.X are obviously covering numbers, but the other ones values are blank. the reason why I ask because I am not achieving ipv6 gateway link with wan ipv6 gateway so I am having to use a script to inject what I determined to be its value. I am trying to see if the values here could be effecting that.
