Hi Guys,
I've recently subscribed to a fibre optic plan from my service provider with the following specs:
Download Speed: Up to 1 Gbps
Upload Speed: Up to 500 Mbps
International Bandwidth: Up to 100 Mbps
My setup is currently like the attached picture. The Huawei HG863 and HG256 (Wireless N Residential Gateway) is provided by the service provider. However, the HG256 is only providing ~100-300mbps on speedtest.net WIRED(if lucky, max 500mbps). On wireless, only ~25-50mbps. Therefore I'm considering to replace the HG256 with a new and powerful wireless router. Can someone please recommend one to me ?
Secondly, on the second level , I am using a WRT610n, connected to the PoE switch and out to the HG256 via Cat6 cable as an Accesspoint (turned off DHCP). However, I'm not sure if I should use the same SSID and Channel. I have no problem with different SSIDs. However, when I changed the SSID to the same name. I'm having weak connections.
Lastly, for level 3, I need another accesspoint with a LAN port as my room's cat6 cable is wired only to level 3. Therefore, hope someone can assist in choosing my equipments.
The last thing i would want is to buy a few routers and then realise that it is not good enough.
I sincerely thank everyone out here for their help.
Thank you
Nycky
Thank you
Nycky
