Need help to understand AX58U log
surfturtle
My router keeps dropping some connected devices randomly, need help understanding the log file. Can you spot any errors?
Mar  9 09:44:02 wlceventd: wlceventd_proc_event(530): eth5: Auth 30:C9:AB:3F:48:D2, status: Successful (0), rssi:0
Mar  9 09:44:03 wlceventd: wlceventd_proc_event(559): eth5: Assoc 30:C9:AB:3F:48:D2, status: Successful (0), rssi:-61
Mar  9 09:44:49 wlceventd: wlceventd_proc_event(530): eth5: Auth 2E:E8:98:97:D4:A6, status: Successful (0), rssi:0
Mar  9 09:44:49 wlceventd: wlceventd_proc_event(559): eth5: Assoc 2E:E8:98:97:D4:A6, status: Successful (0), rssi:-83
Mar  9 10:02:30 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 2E:E8:98:97:D4:A6, status: 0, reason: Disassociated due to inactivity (4), rssi:-93
Mar  9 10:02:30 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 2E:E8:98:97:D4:A6, status: 0, reason: Previous authentication no longer valid (2), rssi:-93
Mar  9 10:02:31 wlceventd: wlceventd_proc_event(511): eth5: Disassoc 2E:E8:98:97:D4:A6, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar  9 10:06:49 wlceventd: wlceventd_proc_event(530): eth5: Auth 2E:E8:98:97:D4:A6, status: Successful (0), rssi:0
Mar  9 10:06:49 wlceventd: wlceventd_proc_event(559): eth5: Assoc 2E:E8:98:97:D4:A6, status: Successful (0), rssi:-81
Mar  9 10:09:12 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 2E:E8:98:97:D4:A6, status: 0, reason: Disassociated due to inactivity (4), rssi:-94
Mar  9 10:09:12 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 2E:E8:98:97:D4:A6, status: 0, reason: Previous authentication no longer valid (2), rssi:-94
Mar  9 10:09:13 wlceventd: wlceventd_proc_event(511): eth5: Disassoc 2E:E8:98:97:D4:A6, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar  9 10:12:34 wlceventd: wlceventd_proc_event(530): eth5: Auth 2E:E8:98:97:D4:A6, status: Successful (0), rssi:0
Mar  9 10:12:34 wlceventd: wlceventd_proc_event(559): eth5: Assoc 2E:E8:98:97:D4:A6, status: Successful (0), rssi:-80
Mar  9 10:48:57 acsd: eth5 received event: tx pkt delay suddently jump
Mar  9 11:35:01 wlceventd: wlceventd_proc_event(530): eth5: Auth DA:D5:EA:52:C2:35, status: Successful (0), rssi:0
Mar  9 11:35:01 wlceventd: wlceventd_proc_event(559): eth5: Assoc DA:D5:EA:52:C2:35, status: Successful (0), rssi:-64
Mar  9 11:49:07 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind DA:D5:EA:52:C2:35, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Mar  9 11:50:36 wlceventd: wlceventd_proc_event(530): eth6: Auth D4:25:8B:DA:C3:89, status: Successful (0), rssi:-61
Mar  9 11:50:36 wlceventd: wlceventd_proc_event(540): eth6: ReAssoc D4:25:8B:DA:C3:89, status: Successful (0), rssi:-61
Mar  9 11:51:13 kernel: ^[[0;33;41m[ERROR archer] archer_mcast_activate,577: ADD_PORT: WLAN SSID has already been added: egress_port 7, current 0x0001, new 0x0001^[[0m
Mar  9 11:58:37 acsd: eth5 received event: tx pkt delay suddently jump
Mar  9 12:18:34 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 2E:E8:98:97:D4:A6, status: 0, reason: Disassociated due to inactivity (4), rssi:-94
Mar  9 12:18:34 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 2E:E8:98:97:D4:A6, status: 0, reason: Previous authentication no longer valid (2), rssi:-94
Mar  9 12:18:35 wlceventd: wlceventd_proc_event(511): eth5: Disassoc 2E:E8:98:97:D4:A6, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar  9 12:42:51 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind C2:2D:F5:E3:38:18, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Mar  9 12:43:46 wlceventd: wlceventd_proc_event(530): eth5: Auth C2:2D:F5:E3:38:18, status: Successful (0), rssi:0
Mar  9 12:43:46 wlceventd: wlceventd_proc_event(559): eth5: Assoc C2:2D:F5:E3:38:18, status: Successful (0), rssi:-50
Mar  9 12:44:25 acsd: acs_set_chspec: 0x100a (10) for reason APCS_CSTIMER
Mar  9 13:00:11 acsd: eth5 received event: tx pkt delay suddently jump
Mar  9 13:00:29 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 30:C9:AB:3F:48:D2, status: 0, reason: Unspecified reason (1), rssi:-61
Mar  9 13:00:29 wlceventd: wlceventd_proc_event(530): eth5: Auth 30:C9:AB:3F:48:D2, status: Successful (0), rssi:-61
Mar  9 13:00:29 wlceventd: wlceventd_proc_event(540): eth5: ReAssoc 30:C9:AB:3F:48:D2, status: Successful (0), rssi:-61
Mar  9 13:00:33 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 30:C9:AB:3F:48:D2, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Mar  9 13:00:39 wlceventd: wlceventd_proc_event(530): eth5: Auth 30:C9:AB:3F:48:D2, status: Successful (0), rssi:0
Mar  9 13:00:39 wlceventd: wlceventd_proc_event(559): eth5: Assoc 30:C9:AB:3F:48:D2, status: Successful (0), rssi:-63
Mar  9 13:00:44 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind C2:2D:F5:E3:38:18, status: 0, reason: Disassociated due to inactivity (4), rssi:-60
Mar  9 13:00:44 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind C2:2D:F5:E3:38:18, status: 0, reason: Previous authentication no longer valid (2), rssi:-60
Mar  9 13:00:45 wlceventd: wlceventd_proc_event(511): eth5: Disassoc C2:2D:F5:E3:38:18, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar  9 13:00:46 wlceventd: wlceventd_proc_event(530): eth5: Auth C2:2D:F5:E3:38:18, status: Successful (0), rssi:0
Mar  9 13:01:44 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 68:37:E9:4E:AE:6C, status: 0, reason: Disassociated due to inactivity (4), rssi:-55
Mar  9 13:01:44 wlceventd: wlceventd_proc_event(494): eth5: Deauth_ind 68:37:E9:4E:AE:6C, status: 0, reason: Previous authentication no longer valid (2), rssi:-55
Mar  9 13:01:45 wlceventd: wlceventd_proc_event(511): eth5: Disassoc 68:37:E9:4E:AE:6C, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Mar  9 13:01:55 wlceventd: wlceventd_proc_event(530): eth5: Auth 68:37:E9:4E:AE:6C, status: Successful (0), rssi:0
Mar  9 13:01:55 wlceventd: wlceventd_proc_event(559): eth5: Assoc 68:37:E9:4E:AE:6C, status: Successful (0), rssi:-50
There's nothing particularly unusual in your log. Those are all normal messages. The only standout device is 2E:E8:98:97:D4:A6 which has a very weak signal and disconnected a few times. That might be normal if it's something like a mobile phone.
