need help with cron job
Grievous Angel
I feel like I'm missing something. I just backed up from the latest semi-official ASUS firmware (372 I think) to the latest Merlin Beta because I want to run a cron job that will restart my wifi every morning (to work around the 5g signal drop).
The update seems to go OK--and even creating the cron job seems to work, it's the reboot that goes wrong. When I reboot, "crontab -l" shows no jobs--and the file I created is gone.
Here are the steps I took:
Installed Merlin's latest beta firmware, then did a factory reset.
Enabled JFFS partition and format on reboot, then rebooted the router.
Ensured the "format on reboot" setting was off after the reboot.
Created a file in /jffs/scripts to create the cron job (per vdemarco's instructions) to run the "restart_wireless" at 5 AM every day.
I ran that file manually. When I do a crontab -l it shows up.
However, when I reboot, the crontab -l shows no jobs, and the file I created in /jffs/scripts is gone.
By the way I was using telnet not SSH . . not sure why I'd use one over the other but I'm not familiar with ssh.
What am I missing? (thanks)
There's currently an issue where the JFFS partition can get reformatted at boot time. You have to manually clear the flag, and commit it back to flash:
nvram set jffs2_format=0
nvram commit
If that doesn't work, then do one more full format:
nvram set jffs2_format=1
nvram commit
reboot
And after reboot, set the flag back to 0 and commit it.
