Need hub recommendations to use with older Amazon echo and app please
I have if you smart plugs from Amazon that I use. I have a wyze camera separately. But I do want to add 2 wifi motion detectors and some door sensors. I need this to be compatible with the Alexa app and routines. It seems like zwave is the way to go. Samsung SmartThings Hub at least on Amazon had quite a few negative reviews and did not seem that reliable.
I'm open to some suggestions for some tried-and-true hubs that people are using and that will interface well and not break the bank. Thank you very much, Peter
