Hi All,
First post here as I need some help.
So in my apartment where I live I currently have an Asus AC1200g+ which has been going on for around 4 years and has been great. The issue is that we are starting to stream content all around the apartment and some devices do not support 5ghz. The apartment is around 140 sqm (1500square feet), the 2.4ghz band is being congested at times and also randomly disconnecting and re-connecting all devices which is becoming annoying.
I am looking into upgrading the router for it to be able to handle more speed and I am in doubt between 2 routers.
The AX86u is the very modern one which I can get for around €300 and from what I heard has good coverage and speed.
The AX88 is an older router and I read that it was released before all this Wifi 6 stuff, I can also get this for around €300 as its on sale.
Which router would you suggest to go for and why? Current setup is that we use 2.4ghz and 5ghz bands heavily and the area is FULL of 2.4ghz. I am upgrading to Wifi 6 as in the coming year or 2 max all our devices SHOULD be Wifi 6 capable and would like to buy 1 and keep the same router.
My main concern is which would be suited best for a thick concrete wall apartment that can handle Wifi Coverage best and is capable of giving out good speeds.
Thank you very much!
