I have moved and my wireless set-up is no longer cutting the mustard. My set-up is an E4200 router and I have been using a Netgear 5Ghz bridge connected to my media streamer. In my old place this speed was fine. I have moved and the distance has been extended to 70 feet and it's just not good enough, on my laptop I'm getting 800kb/s on the 5Ghz N and 2.7MB/s on the 2.4Ghz G. Move to 2.4Ghz N and it goes to 4.7MB/s N. At this distance my PS3 won't even stream Netflix, weak radio in that thing I guess Considering that this router does not have the ability to add external antennas it would a appear a 2.4Ghz bridge would be the way to go. I am not flashing dd-wrt. I don't need any added functionality to my router and unless it greatly improves range I don't want to risk bricking a $180 router.
From the looking I've been doing N bridges are ridiculously overpriced. So I am eying the Buffalo WHR-HP-G300N router since it has built in dd-wrt and a simple box tick will turn it into a bridge. Thoughts on it?
I am open to any and all suggestions but the price has to be under $100 and under $50 is even better. It must have at least two ports(WD streamers and PS3) with three even better.
