Netbug
hi,
i'm running merlin latest beta 382.2 for RT-AC68U. I know merlin firmware and asus firmware don't have a web gui for making vlans which brings me to my question.
I want to see how others have gone about setting up vlans. I want three vlans one for my laptop/mobile and other devices that i trust, another vlan for guests and another vlan for IOT devices, i basically want to isolate my network however i want my mobile to be able to communicate with all vlans as many devices now comes with apps to control products via mobile apps.
i was thinking of buying a layer 3 switch plugging it in to my router then plug a access point into the switch, setup multiple ssids and assign vlans to the different ssids. I never done this before so don't know if there a cleaner/easier/cheaper solution? i now about guest network but its too limited. Reason i mention access point is because everything i have is connected via wifi not ethernet.
I'm not an expert but do run ab-solution, skynet, openvpn etc so looking for different advice, i've been researching allot online, some go all out and buy 3 routers which i think is overkill, i would prefer to not have to buy a switch and access point but will if its a good solution, any recommendations advice much appreciated.
My current setup is simple:
phone socket > draytek modem > router, everything connects via wifi not ethernet.
Thank you.
Thank you.
