Need som help with vpn-ip number order
octopus
Part of the Furniture
Need som help/suggestions to get this working.
I use this script to monitor endpoint vpn-ipnumber.
I have two vpn-clients running, 1 and 3 and depending how it starts up I get display 1/ 2 in defferent order.
Also is doesn't matter if I use ovpnc1 or 3 I get same result in both way.
I wan't to use vpnclient-1 always been used/displayed.
Have someone any brilliant sulution?
cantshow1="Can't show vpnroute-ip 1"
cantshow2="Can't show vpnroute-ip 2"
display=$(ip route show table ovpnc1 | grep "via $(nvram get wan0_gateway)" | awk -F' ' '{print $1}')
display1=$(echo $display | cut -d' ' -f2)
if [ -z "$display1" ]; then
display1=$cantshow1
fi
echo $display1
display2=$(echo $display | cut -c 1-14)
if [ -z "$display2" ]; then
display2=$cantshow2
fi
echo $display2
octopus@RT-AC68U:/tmp/home/root# route
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
193.187.91.199  gw11.A444.priv. 255.255.255.255 UGH   0      0        0 eth0
158.xxx.xxx.1  *               255.255.255.255 UH    0      0        0 eth0
217.64.148.49   gw11.A444.priv. 255.255.255.255 UGH   0      0        0 eth0
10.8.30.0       *               255.255.255.0   U     0      0        0 tun22
192.168.12.0    *               255.255.255.0   U     0      0        0 br0
158.xxx.xxx.0   *               255.255.252.0   U     0      0        0 eth0
10.128.0.0      *               255.255.0.0     U     0      0        0 tun11
10.129.0.0      *               255.255.0.0     U     0      0        0 tun13
127.0.0.0       *               255.0.0.0       U     0      0        0 lo
default         gw11.A444.priv. 0.0.0.0         UG    0      0        0 eth0
Also is doesn't matter if I use ovpnc1 or 2 I get same result in both way.
display1=$cantshow1
fi
echo $display1
display2=$cantshow2
fi
echo $display2
Definitely not a "brilliant" solution as you requested, but perhaps my ugly hack meets your main criteria?
e.g. The status of both VPN Client 1 and VPN Client 3 is always displayed in ascending order.
PRIMARY=1;SECONDARY=3;INDEX=$PRIMARY
ACTIVE=$(ip route | sort -k3 | grep -E tun1[${PRIMARY}"|"${SECONDARY}"]" | cut -d" " -f1,3)
if [ -n "$ACTIVE" ];then
   echo "" >/tmp/$$
   echo "$ACTIVE" | while read LINE
      do
         [ -n "$(echo "$LINE" | grep "tun1"$INDEX)" ] && { echo -e "\n\t"$LINE"\n"; echo $INDEX >/tmp/$$; } || { echo -e "\a\n\tCan't show vpnroute-ip" $INDEX"\n"; echo  -e "\t"$LINE"\n"; }
         INDEX=$SECONDARY
      done
      [ "$(cat /tmp/$$)" == "$PRIMARY" ] && echo -e "\n\tCan't show vpnroute-ip $SECONDARY\n"
      rm /tmp/$$ 2>/dev/null
else
   echo -e "\a\n\tCan't show vpnroute-ip $PRIMARY\n\tCan't show vpnroute-ip $SECONDARY\n"
fi
Thank you
I have tested and get this answere:
10.128.0.0/16 tun11
10.129.0.0/16 tun13
But it's not what I'm out after.
It's respond from this:
193.187.91.199
217.64.148.69
Which can come in different order in chain.
Thank you
10.128.0.0/16 tun11
10.129.0.0/16 tun13
193.187.91.199
217.64.148.69
OK, just to clarify.
For all of my VPN Clients, I use 'Redirect Internet traffic=Policy Rules (strict)' so the following command you supplied
ip route show table ovpnc? | grep "via $(nvram get wan0_gateway)" | awk -F' ' '{print $1}'
always returns NULL :confused: and there are no 'VPN Client eth0' entries created in the 'route' table.
However, if I set 'Redirect Internet traffic=Policy Rules', then
now produces output. :)
So it appears that when a VPN Client initialises, a new entry for 'eth0' appears in the 'route' table
e.g. your two VPN Clients are ACTIVE
but there is no way to determine which VPN actually owns the destination Gateway IP address entry above.
i.e. you want to know which VPN Client instance created say entry 193.187.91.199 ?
Is this correct?
Is this correct?
Yes, to both. I want to make sure they come in right order every time so I can use one for eg vpn client1.
Strange is when use "ip route show table ovpnc1" it shows both ip-number.
I think if they come in order below it's only display vpnclients1 ip-number by ovpnc1.
Is this correct?
Hi
I have done some more testing and have some questions.
I detect CN= in vpnclient-1.log and get answer and that is right ip-number. Howe to use nslookup with this "cat" string?
cat /tmp/vpnclient-1.log | grep -E -m 1 "CN=v" | awk -F' ' '{print $9}' | cut -d '=' -f2
vpn20.prd.kista.ovpn.com
Ok got it:
CN="$(cat /tmp/vpnclient-1.log | grep -E -m 1 "CN=v" | awk -F' ' '{print $9}' | cut -d '=' -f2)"; echo $CN
This working:
nslookup "$CN" | grep -woE '([0-9]{1,3}\.){3}[0-9]{1,3}' | awk 'NR>2'
217.xx.xxx.58
Edit: Is't any other way to monitor "CN=" other then vpn-client-log?
