Hi all,
I need some advice on a setup i intend to do.
I currently have a R7000 (Nighthawk).
My Internet line is (1 Gbps Fiber).
The current connection is
Fiber Termination Point ---> ISP ONT ---> R7000 ---> (LAN to PC - Wired)
What i intend to do is
Fiber Termination Point ---> ISP ONT ---> Sophos UTM Home Edition running on a PC ---> (PC connected directly on one NIC port) ---> R7000 on another NIC port (in AP mode for wireless only)
Note that my ISP ONT gives me a static IP address via DHCP.
I intend to get the following hardware for the Sophos UTM Home Edition that i'll be going for.
OS : Sophos UTM Home Edition
Case : SilverStone RAVEN Series RVZ01B
CPU : http://ark.intel.com/products/78927/Intel-Core-i5-4460T-Processor-6M-Cache-up-to-2_70-GHz
Motherboard : Not decided yet - Mini-ITX form factor
NIC : Intel Quad Port Server NIC Model E1G44ET2BLK
My concerns are whether the hardware is adequate (I'm concerned about the WAN throughput performance (with IDS/FW turned on only and nothing else) as well as WAN to LAN throughput performance (will i be able to minimize loss here with this setup?)
Also, does anyone know if the throughput of the Sophos UTM Home Edition is good enough to deliver near good speeds?
The fastest i've gotten on the R7000 is about 900+ Mbps but this slows down considerably over time (for some reason, the R7000 firmware ages and the only way to fix this is a factory reset, reboots don't help PS : QoS is off along with pretty much everything else. Router just does DHCP and Wifi)
Need your expert advice.
