Need some help with "sed" command
octopus
Part of the Furniture
Need some help with sed command.
I want to remove ":" from CPU out from this line: cpu="`cat /proc/dmu/temperature | sed 's/ø//'`"
Now I get this out put: CPU temperature : 77C
How about:
cpu="`cat /proc/dmu/temperature | sed 's/ø// ; s/://'`"
or even the non-depreciated form
cpu="$(cat /proc/dmu/temperature | sed 's/ø// ; s/://')"
cpu="$(cat /proc/dmu/temperature | sed 's/\t: /XXXXX/ ; s/øC$/YYYYY/')"
Notice how the " : " is actually <tab><colon><space>
cat /proc/dmu/temperature | hd
00000000  43 50 55 20 74 65 6d 70  65 72 61 74 75 72 65 09  |CPU temperature.|
00000010  3a 20 38 35 f8 43 0a 0a                           |: 85.C..|
Thats give:
octopus@RT-AC68U:/tmp/home/root# cat /proc/dmu/temperature | sed 's/\t: /XXXXX/ ; s/øC$/grder/'
CPU temperatureXXXXX75
Prefered output is: CPU temperature 75 degrese
cat /proc/dmu/temperature | sed -r 's/\t: // ; s/([0-9]{1,3})/ \1 degrese/'
When tested from xshell i get this out:
octopus@RT-AC68U:/tmp/home/root# cat /proc/dmu/temperature | sed -r 's/\t: // ; s/([0-9]{1,3})/ \1 degrese/'
But when in this case sending mail I get signs at then end: " øC "
CPU temperature 75 degreseøC
Thanks !
Thanks !
Hmm strange... ;)
deja vu ?
A fairly horrible solution:
# cpu="$(printf "The temperature is %s degrees" $(cat /proc/dmu/temperature | sed 's/[^0-9]*//g'))"
# echo $cpu
The temperature is 82 degrees
Not strictly 'sed' o_O
sed -r 's/\t: // ; s/([0-9]{1,3})/ \1 degrese/ ; s/C$//' | tr -d '\xf8'
Thank you!
That working fine nothing more " øC " . I can read In mail: CPU temperature 77 degrees
2.4Ghz radio    50 Grader
5.0Ghz radio    52 Grader
CPU temperature 76 Grader
Thanks for all help. I have forgot about that deja vu.......... getting old :(
cat /proc/dmu/temperature | cut -d ":" -f 2
Thanks, that is also a solution and I can use my own text. ;)
But I get "77øC" as result when email from my scriptit.
Your code returns the spurious 2-char unwanted suffix that is invisible i.e. non-printable
CPU temperature : 74
i.e. how can the length of the expected 2 digits be 7 chars rather than 3 (includes leading space) or 5 if we include the two trailing LF chars?
cat /proc/dmu/temperature | cut -d ":" -f 2 | wc -c
7
It's only invisible because you are using an incompatible character set (the last "C" should always be visible anyway). So if you use ISO-8859-15 for example:
CPU temperature : 84øC
Anyway, if @octopus wants to use completely different text then the solution in post #11 will work.;)
Thanks to all of you!
Both ways working just fine:
cpu="`cat /proc/dmu/temperature | sed -r 's/\t: // ; s/([0-9]{1,3})/ \1 Grader/ ; s/C$//' | tr -d '\xf8'`"
cpu="$(printf "CPU temperature %s Grader" $(cat /proc/dmu/temperature | sed 's/[^0-9]*//g'))"
Octopus
@ColinTaylor @RMerlin @Martineau
If this helps... snippet from another script I keep around...
#!/bin/bash
celsius=$(cat /sys/class/thermal/thermal_zone0/temp | sed 's/.\{3\}$/.&/')
echo "ARM Temp => ${celsius} °C"
which results in...
ARM Temp => 53.692 °C
tweak as needed - regular expressions are fun, until they're not :D
