amtm Need some NVRAM outputs of Aura capable routers (resolved)
thelonelycoder
Part of the Furniture
Hey all
I'm testing a new feature in the lc LED control feature of amtm.
To determine what values are set I need some NVRAM outputs of Aura capable routers. These are the ones that have shiny changing colors - I do not own such a fancy router.
Please copy the complete one-liner command and paste it into the SSH terminal and press Enter, then post the output here.
It will read out a bunch of variables and their setting, along with the router model for clarity.
Thanks a bunch for helping to everyone who participated!
I have all the data I need to continue coding this feature.
Hey all
Thanks a bunch for helping!
[ -z "$(nvram get odmpid)" ] && model="$(nvram get productid)" || model="$(nvram get odmpid)"; printf "Router Model: $model\\n"; for nvr in ledg_scheme ledg_scheme_old ledg_qis_finish ledg_led_enable ledg_led_finish ledg_rgb1 ledg_rgb2 ledg_rgb3 ledg_rgb7; do echo $nvr: $(nvram get $nvr);done
Router Model: RT-AX82U
ledg_scheme: 6
ledg_scheme_old:
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
ledg_rgb1: 0,100,128,0,50,128,0,0,128,30,0,128
ledg_rgb2: 128,0,0,128,0,0,128,0,0,128,0,0
ledg_rgb3: 0,0,128,0,0,128,0,0,128,0,0,128
ledg_rgb7: 0,0,128,0,0,128,0,0,128,0,0,128
# [ -z "$(nvram get odmpid)" ] && model="$(nvram get productid)" || model="$(nvram get odmpid)"; printf "Router Model: $model\\n"; for nvr in ledg_scheme ledg_schem
Router Model: GT-AX6000
ledg_scheme: 7
ledg_scheme_old: 7
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
ledg_rgb1: 0,0,128,0,30,128,0,50,128
ledg_rgb3: 0,56,128,0,56,128,0,56,128
ledg_rgb7: 0,28,128,0,28,128,0,28,128
This looks like Aura is enabled but you never switched it off after setting it to on?
No? I just ran the command you provided, do you want me to run it with Aura set to off?
It seems to give the same result when set to off
ledg_scheme: 0
ledg_scheme_old: 6
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
ledg_scheme_old: 6
This confirms that this variable gets set to the selected theme when turning Aura off. Is it empty now when Aura is turned on again?
Aura mode ON:
ledg_scheme: 6
ledg_scheme_old: 3
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
Aura Mode OFF:
ledg_scheme: 0
ledg_scheme_old: 6
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
Aura Mode ON: (but different scheme)
ledg_scheme: 3
ledg_scheme_old: 6
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
EDIT: The default scheme is zero
Hey all
Here you go (default settings):
ASUSWRT-Merlin GT-AX11000_PRO 3004.388.7_0 Fri Apr 26 18:22:46 UTC 2024
Router Model: GT-AX11000_Pro
ledg_scheme: 1
ledg_scheme_old:
ledg_qis_finish: 1
ledg_led_enable: 1
ledg_led_finish:
ledg_rgb1: 20,0,128,110,0,100,128,0,80
ledg_rgb2: 148,0,128,148,0,128,148,0,128
ledg_rgb3: 20,0,128,110,0,100,128,0,80
ledg_rgb7: 20,0,128,110,0,100,128,0,80
ledg_scheme: 7
ledg_scheme_old: 2
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
ledg_rgb1: 128,0,0,128,20,0,128,50,0
ledg_rgb3: 128,0,0,128,0,0,128,0,0
ledg_rgb7: 128,0,0,128,0,0,128,0,0
Aora: on
No, once populated with a value, it retains the value.
Looks like some routers have two additional NVRAM settings, like the GT-AX11000_Pro and the GT-AXE16000.
ledg_led_enable
ledg_led_finish
Could be an AiMesh node thing or something other?
ledg_led_enable
ledg_led_finish
From GT-AX16000 AiMesh node:
Router Model: GT-AXE16000
ledg_scheme: 7
ledg_scheme_old: 6
ledg_qis_finish: 1
ledg_led_enable: 1
ledg_led_finish: 1
With AURA mode OFF:
ledg_scheme: 0
ledg_scheme_old: 2
ledg_qis_finish: 1
ledg_led_enable:
ledg_led_finish:
If ledg_scheme=0 then Aura is off from my understanding.
Yeah maybe, i havent payed attention to it, and i don't know if the Aura has been turned on/off or something similar. That router is not at my place :p
Aura was turned on with wave as theme when i ran the command (that was my first post).
I believe you're right....I believe when the router is initially setup, the Aura is "on" by default. Mine shows
ledg_scheme=1
as I just setup my router and I didn't mess with Aura RGB setup.
The Asus app shows:
Thanks guys for helping me out, I have now all the info I need to continue coding.
Expect a new feature with the next amtm release ;)
