Netflix blocking network devices outside of OVPN Tunnel ?
kudzero
I have the Asus rt-3100 with the latest version of AsusMerlin FW. I can connect to my vpn provider using open vpn in the router settings. I have set up policy based routing for 3 device IPs to use the vpn on the router and the rest of the devices to use the wan. The routing policy works, only the 3 devices go through the vpn and the rest go through the wan. But now no IP address using the wan can open Netflix. I have tried the JFFS script for VPN routing policy but I am getting the same results, any ideas?
Forgot to mention when the VPN is completely off netflix works fine..
