aldo
Apologies in advance if this is the wrong section of the forum.
The R7000 is wireless but my access speed problem is via gigabit LAN, so I wasn't sure where to post.
I ran some tests transferring a folder with two videos, 2gb in total, back and forth.
My problem is that via LAN cable, I am getting transfer speeds of between 25 MB/s transfering to the router and 30 MB/s transfering to my laptop.
All reviews I could find seem to suggest that with my setup 50 MB/s would be achievable,
The hard disk is in NTFS, but I also created an ext4 partition to test, perhaps slightly faster but really no appreciable difference. Same with FTP, downloading through a browser
I have an R7000 and a Seagate STBV5000200 Expansion 5TB USB 3.0 external hard drive hooked to it. I understand it's a SATAIII and some reviewers mesured over 100MB/s when connected directly to a PC.
The R7000 OS is the stock one, I tried with the firmware 'out of the box' and then upgraded to the newest one with no improvements.
My network settings are the standard ones created automatically by the router via EasyShares, so I am accessing via samba with an oldish ubuntu laptop, gigabit LAN and SATAII 5400 rpm internal hardrive
I also tested with an old macbook and snow leopard, getting even less, around 10MB/s, but it's just SATA interface.
Not quite sure what to try next..
Shall I go for a different transfer protocol? Not even sure how easy it would be to setup.
My LAN cable is a 4 meters long 5e , not 6. Can that make a difference?
I am unable to test speed over AC wifi right now, I got some excellent advice on this forum about an internal AC card but I haven't got around buying it yet.
