zOlid
I have just bought a new ac66u router. (running latest standard firmware)
And i transferred my setting from my n66u router to it.
On my n66u i had a beta firmware that had IPTV improvements.
And the Traffic monitor did not work.
And now when i transferred the settings the traffic monitor wont work on the ac66u either.
So i did a 30/30/30 to reset nvram. And thought that would help the situation.
Re did all the settings manually. But the traffic monitor still wont work.
What is the problem?
Shouldn't a 30/30/30 reset do the trick?
All the settings i had where gone at least.
Also i have issues with the 5ghz band dropping every now and then.
But as i understood it this is a problem all have?
Is there any solution to this issue?
