Network Printer Not Showing
owlyn
RT-AC66, Merlin 376.45. Not a huge deal, but the detection/connection icons in the top right corner (underneath the Language choice drop down) indicate that no printer is detected, yet my printer is on Port 4, and works fine. The printer is a Canon MX972 (Printer/Scanner/Copier/Fax). It does show up on the Network Map (and I am using IPv4 for the printer).
Just wondering if the icons should show a printer, or is it only looking for USB printers, or maybe it is a bug? Again, not a huge deal, as the printer works properly from all connections through the router, including WiFi.
Thanks.
