I assume just because the Network Services Filter talks in terms of LAN --> WAN rules that I can still add rules essentially LAN --> LAN? I'm trying to block access to one IP on the same subnet on port 80 (any:any --> RFC1918 Class C IP address:80), but the rule does not work. Parental controls are not enabled so I assume it should work?
I'm on the latest Merlin firmware (much better than stock, many thanks), but I find it bizarre that after spending over $200 on an Asus RT-AC87U (an otherwise awesome router) that the Network Services Filter does not appear to work as standard. Having to SSH to the box & manipulate iptables is not what I was expecting, when you consider the Network Services Filter feature is meant to add custom fw rules for you.
Is there any possibility of Asus (or Merlin) activating the functionality of Network Services Filter?! Not sure what I'm doing wrong...did not expect my transition from a pfSense fw (don't ask) to this setup to be MORE complicated!
Any help would be most appreciated, thanks.
