sman
Hi there,
I plan to upgrade to WIFI 7 and use the VLAN too. I am not an advanced user and need recommendations.
I have to mention from the start, that I'm not expressly interested in wireless speed as much as wired fluidity matters.
In the attached sketch you can see the existing topology:
Devices in Main router + 10 GB Switch: Ubuntu server with LAMP and more (this is most important device of network and req. max priority for low latency), Win11 Media server, 2 PC, Node 2i, 8 wireless devices.
Devices in Node2. A lot of IoT devices on wired ports: 3 TVs with Netflix, 3 IP cam, 2 PC's. Looks like I need a switch here.
Wireless there are 8 phones, laptops etc.
I have some questions:
1. Are the ports in the ROG-GT-BE98 or RT-BE-88U base router Layer 3? If so, what type? CPU based or Hardware acceleration? Apropos, which is more suitable for wired connections ROG-GT-BE98 or RT-BE-88U ?
2. Do AIMESH NODES necessarily need to be made up of routers that have the VLAN feature? e.g. RT-BE86U, RT-BE96U ? This is very important because I don't know if the MAIN Router is using resources from the VLAN function of the NODE(S) Router. If the VLAN feature of the NODE are not used by the MAIN Router I am thinking to buy a RT-BE92U - better wireless, no VLAN feature available and it's cheaper.
3. For traffic flow is it recommended to connect Node 1 and Node 2 with a wired connection? Of course I will enable Spanning-Tree Protocol - STP. Fortunately there is a CAT5 cable between these two nodes. I mention that in node 1 there is little traffic and I was thinking that maybe load balancing between the nodes and the main router.
4. Can the Main Router create VLANs for IoT devices placed in physical (not wireless) ports in Node2? I mean without direct connection in the main router ports.
Thanks for any hints and help
