speedingcheetah
ASUS RT-AC56U Firmware version 3.0.0.4.374.339
Added
1. Added OpenVPN server.
2. Added OpenVPN/ PPTP/L2TP client.
3. Some devices like set top box, smart TV or Blu-ray player are not able to establish VPN connection. VPN client in router can help these devices to connect to VPN server.
4. Added roaming assistant: allow to set the minimum RSSI to disconnect clients and let clients reconnect to Ap with better signal.
5. Added import CA file and manual edit option in OpenVPN client
6. Added option for tls-auth in OpenVPN server
7. Added private WAN IP checking in VPN server page.
Modified:
1. Enhanced FAT32 read/write speed
2. Modified roaming assistance algorithm for better roaming experience.
Fixed
1. Fixed OpenVPN server *.ovpn file exporting issue while changed the protocol to TCP.
2. Fixed PPTP VPN client related issues.
3. Applied memory leak patch in media server.
4. Improved the 2.4GHz wireless throughput.
5. Improved the samba throughput while IPv6 enabled.
6. Adjusted 2.4GHz power saving algorithm to fix slow wireless in some special scenarios.
7. Fixed ASMedia 1053E USB 3.0 controller compatibility issue.
8. Fixed IPv6 related issues
9. Fixed quick internet setup UI issues when setup the router by wireless client.
10. Fixed WPS push button related issues.
11. Fixed the security related issues for httpd.
12. LAN user can now connect to OpenVPN server with DDNS name.
13. Fixed IPv6 default route missing issue.
14. Fixed BitTorrent related issues.
http://www.asus.com/us/Networking/RTAC56U/#support
So far..all seems good....no issues torrenting and my PPPoE connected fine.
(I haven't tried OpenVPN...as I use the VPN from my Win Server 2012 system.)
Wifi speeds on 5ghz are excellent!
Anyone else try this update?
Also, I thought I saw in some other threads that the newer firmware would increase the memory clock of the router from 533 to 667...does that affect the AC56U?...(or was that for another model?) Do I need to reset the router or something for such a change to take affect?.... How do you check memory frequency on stock firmware?
Added
Modified:
Fixed
