I'm new to this group and looking for some advice on network architecture for a new home under construction. I think this is the appropriate section for this post, but if not please direct me to the right one. I've read many of the articles on this site which has provided much needed insight on the decisions I'm faced with. The good news is, we're in the early stages of construction and I have a few months to plan things out before we start running cable.
The home will be one-story with a walkout basement + garage, 4 bedrooms, everything else fairly typical. I plan to wire with CAT6 everywhere is seems reasonable to do so, and will likely provide at least 2 wireless access points, one per floor. I've identified 12 separate areas for a CAT6 wall jack. For the wired portion, my initial concept would be to simply "home-run" each of these to a 16-channel switch, and from there to the router and WAN modem. I read the article "How to Improve Network Performance" by Doug Reid, in which he explained the advantages of using separate components for modem, router and switch, rather than the combo boxes which the ISPs offer. My first question is where and how to fit the wireless access points into this design. The wireless routers seem to get most of the market attention nowadays, and some preliminary browsing of the router charts on this site indicate that they are generally cheaper than the wired-only routers. Would it make a difference performance-wise for one of these options:
1) use a wired-only router for the main WAN/LAN access and use wireless access points further downstream as nodes on the switch? Or
2) Use the "wired" portion of the wireless router for WAN/LAN but still use it for wireless access as well. I would still likely need at least one additional wireless access point on the other floor.
I appreciate any advice/feedback you can offer.
