GegiDancer
My family is remodeling the wifi setup in our home. It is made out of two connected hauses, each around 1500sqft -see the image.
The current wifi setup lacks especially on the range of routers. There is a floor plan with all the signal strenght in the image bellow, the x marks the routhers, and its colour defines the range. A circled x is a wired routher, yes thesse are all of possible wired access points. The main routher-modem is the red X. The wifi signal sadly lacks on all the exclamation marks. Routers we use now are Edimax BR-6428nS V3.
What routers and system would you choose on the setup?
Was thinking of aimesh system for one common ssid. Three band on the primary router, so there is possibility for undisturbed extenders in the upper and lower floor? Which routers would be the best for the job?
If you have any videos or text that would help me choose please let me know!
Thank you!
Thank you!
