overdrive31
Never really used WPS in the past, but taking advantage of it with the R7000 has been more trouble than what it's worth. I hope it is just a firmware bug, but I will have to test it with other hardware to see. Each time I use the push button WPS, my DD-WRT client bridge's break and need a reboot...why? lol
I expected a router that supports IPv6 as well as an VPN server, to allow you to take advantage of both features. As it turns out, I must choose one or the other. Disappointing, and the DD-WRT builds don't seem to provide both features either. Any device behind my client bridge's also will not receive an IPv6 address. Research has found that an IPv6 address will only pass using a WDS implementation.
I wonder, if an DD-WRT WDS bridge could also host an OpenVPN server to cover the needs of IPv6 and a VPN server. Can the ASUS RT-AC68U support both IPv6 and the OpenVPN server simultaneously using any of it's available firmwares?
