I mainly use the internet for streaming and my son as a playstation.@Brads27
Keep it simple. What do you want to get out of a new "router" ? What do you use the internet for? Do you need to drop $500 on a router when a cheap $100 option exists? Do you just need to add an AP for better WIFI instead of a router?
Ok, so, that should be easy to accomplish.I mainly use the internet for streaming and my son as a playstation.
It's WiFi in a different room upstairs.Tv is WiFi as well.As far as I know.Ok, so, that should be easy to accomplish.
If the PS wired or wireless? Is it hooked up to thwifi e TV in the same room? Does the TV have an Ethernet port or only WIFI?
My last router was an AX88U
AX88U in my experience has better range than AX86U. Get the newer GT-AX6000 as suggested already.Yes I probably will or the AX 11000,e way I look at it, I got £300 refund so just to that up and I'll have a new router .
The hardware model AX82U (CPU, Flash, RAM, radio chip) is identical to AX58U.
The only difference is the housing design.
Welcome To SNBForums
