Netconnect
Hello everyone,
I was renting a router from my ISP and decided to buy my own. I am connected to a 1gb fiber cable.
I found some threads on a similar problem but couldn’t find a solution except contacting Asus support for warranty.
So basically it works, I installed it and configured it to work with the 2.4 and 5Ghz bands separated. Didn’t touch the default settings in the beginning.
Devices connected via LAN work flawlessly. Mobile devices connected via the 5Ghz network work as well and I get really nice download speeds.
The problem is that either I can’t connect to the 2.4Ghz network, or that it connects but says there is not internet, or connects but responds really slowly and shows download speeds of ~5mbps. I tried this with multiple devices.
I tried changing some settings I saw in other threads: disabling wifi 6, changing bandwidth and switching control channels.
I installed merlin which didn’t help and did a factory reset which didn’t help as well.
All help will be appreciated,
Thank you!
Thank you!
