I recently bought two AX58U routers that i use in an AiMesh. So far i only use stock firmware.
New firmware came out yesterday and i would like to update the firmware on both node and router.
In which order should i update the router and node?
From what i have read here on the forum it is often advised to reset routers after a firmware update.
If so, how should i proceed:
a) reset the node first, connect it to my pc and update the firmware and then setup the AiMesh again.
or
b) Update the node through router GUI, reset and then setup AiMesh again.
or
