ToonTonic
Hi all,
I have recently purchased the GT-AXE11000, and immediately added the Merlin OS as that is what I have been using for years on my RT-AC88U. An issue I have come across is when either router on this OS reboots, I lose internet connection to my devices. Devices like Philips Hue hub lose outside connection, mobile phones are “connected but without internet” etc.
No amount of reboots, power flushing etc works. About the only thing that does work is factory resetting either of the routers and then starting again.
This has actually been a long ongoing issue with the RT-AC88U, and when it most recently happened I gave up with it and bought the AXE11000. As a test on this new router I did nothing but install MerlinOS on the new router, install the NextDNS CLI, leave it running for a few hours and then reboot. The exact same issue occurred.
Now, upon conducting this albeit unscientific test, I have come to the as yet unconfirmed, but probable, conclusion that NextDNS CLI may be the issue. Though this doesn't seem to be a super common issue on good ol google, certainly not on NextDNS boards, so I can't be sure.
I should also throw into the mix that I have the last Merlin update installed on an RT-AC86U, with NextDNS CLI installed, and that does not show the same behaviour.
I am hopeful somebody will be able to guide me, though I must say in advance that upon reading some posts in here, I am not proficient at long lines of code, as simple as I know it may be to many of you in here.
Any questions, feel free to ask away, and I will respond as good as I can, I would really like to resolve this issue, especially if it means I could return this £500 router and save some money. Gas bills aren't getting any cheaper, apparently!!
Cheers
Cheers
