Hello,
hoping my post is in the right discussion.
Context :
I'd like to setup an openVPN server on my router (RT-AC5300, Asuswrt Merlin 386.4), to access some of my LAN devices from internet (printer, NAS,...)
Since some of my clients don't support TAP, I've got to setup TUN type.
Then I configured a VPN network 192.168.3.1/24, while my router LAN network is 192.168.2.1/24.
I've setup and tested one of my clients successfully (as far as connection to VPN server is concerned).
Issue :
From the client 192.168.3.2), I can ping the VPN server (192.168.3.1). But I cant' ping the LAN server (192.168.2.1), nor for example the NAS on the LAN (192.168.2.2).
The same from any device on the LAN : I can't ping neither VPN server (192.168.3.1) nor any VPN client (192.168.3.x).
Then, is there static routes to define explicitly, to allow VPN clients access to LAN ressources ?
I've tried to setup these (Menu LAN > Route) :
Network Netmask Gateway Interface
192.168.3.1 255.255.255.0 192.168.2.1 VPN
192.168.2.1 255.255.255.0 192.168.3.1 LAN
But it doesn't solve the issue.
Note: concerning interface, I don't really know what is the right choice among LAN, MAN, WAN, VPN.
I even have doubt about VPN, since my router is also configured as VPN client (NordVPN like), so is this interface the server I'm trying to setup or the client one ?
User manual is not verbose about the case.
And I've searched a lot on internet about my issue, but most of the time there's only a quick how to setup a VPN server, "and voila !", without dealing with the fact that TUN type forces to get a subnet different from the LAN.
If someone already encountered and solved my issue, it will be very helpful.
Any other advice is also welcome, of course.
Thanks by advance
Context :
Issue :
Thanks by advance
