No connection on one PC after firmware upgrade
NExile
System: Asus N66U router, two Intel PCs with Intel ethernet adapters
just upgraded to RT-N66U_3.0.0.4_376.49_5.
Did factory reset/power cycle/factory reset AFTER flashing firmware.
PC that I flashed from: connects fine.
Another PC on network, Windows 7, Intel ethernet adapter: no connectivity.
Says it is now on a "public network", won't let me alter it.
I googled various solutions, none worked.
As far as I can recall, this is the first time I have flashed new firmware and had an issue like this. (Used to be active in DD WRT forums, Tomato, etc. Merlin is pretty awesome.)
But: I don't know what I did here.
Help?
Thank you!
Help?
Thank you!
On the PC, go the the wi-fi signals and tell the PC "to forget" this ssid.
After that reconnect.
Thank you!
I forgot to mention: hard wired with Monoprice Cat6 cables, no wireless.
I got it working again.
Very strange: I had the DHCP pool set to 192.168.1.2 to 192.168.1.22: when I finally got into the Asus firmware, that had been changed to
from 192.168.1.2 to: 192.168.1.2 i.e. only one DHCP address was available.
I am not sure how that happened, but it's probably something I did or set wrong. (Again, I did "factory reset/clear NVRAM" after flashing the newest Merlin firmware, then reentered all setting by hand, not from a saved configuration file.)
Anyway, thank you!
