Where you able to get this sorted? I just realized mine shows the same:Why is this window always empty? I cant figure out what setting I dont have correct?
You can enable it without emailing iirc and choose to only save to disk. That should suffice to show them in the uiDivStats screenNo, weekly stats not enabled. Don't need more emails!
Opening uiDivStats at the command line should sort out the symlink to the stats if you're impatient!I did enable it to save to disk. I also 'Compiled current stats report'.
I guess I'll have to wait to see it show up in the GUI.
Thread starter | Title | Forum | Replies | Date |
K | Skynet No data to display for only outbound? | Asuswrt-Merlin AddOns | 5 | |
G | Skynet SkyNet Seems to be installed and running, but NO DATA in Merlin - SOLVED | Asuswrt-Merlin AddOns | 3 |
Welcome To SNBForums
