Same router and same issue.In my RT-AX86U with Merlin 386.4 I have only “Amazon Alexa” menu and no IFTTT Tab.
With Asus stock firmware there was “Alexa & IFTTT”.
Why was it removed?
Thanks.
That won't work. The rest of the code is compiled with it disabled.If you really still need access to the IFTTT tab you can probably navigate to https://yourrouterip/Advanced_Smart_Home_IFTTT.asp and access it.
I didn't make any decision. If Asus disables it on their end, then the code won't be compiled with support for it, and I can't re-enable it.It's a shame you decided to leave it out when ASUS give no reason to remove it. It did work.
Welcome To SNBForums
