Hi there,
I have a problem with my Asus RT-AC68U (Firmware:386.14_2) when trying to use OpenVPN through stunnel.
I use the same configuration separately on my MacBook, VM on Linux, Windows. It works fine (openvpn to 127.0.0.1 + stunnel to external vpn server).
When I'm trying to repeat this configuration on my router (without need to do it on each client) I see this working only from router console (ssh) but not for connected clients.
Redirect Internet traffic through tunnel: Yes (all)
My steps:
1. Check internet connection
- from router console (working)
- from client (working)
2. Turn OpenVPN client ON.
3. Check internet connection
- from router console (not working)
4. Manually add route which was in the log but actually wasn't in the route table
ip route add 83.10.10.10 via 10.8.8.5 table ovpnc1 #where 83.10.10.10 e.g. my external VPN server ip
5. Check internet connection
- from client (not working)
So, there are 2 problems:
1. VPN external ip is not added to the ovpnc1 table
2. When it was fixed manually internet vpn connection works from router itself but doesn't from clients.
Please advice.
client
dev tun
proto tcp
remote 127.0.0.1 1194
resolv-retry infinite
nobind
user nobody
group nobody
persist-key
persist-tun
remote-cert-tls server
cipher AES-256-GCM
verb 3
foreground = yes
[openvpn]
client = yes
accept = 127.0.0.1:1194
connect = 83.10.10.10:1111
verifyPeer = yes
My steps:
curl api.myip.com
{"ip":"my_ISP_ip","country":"my_country","cc":"XX"}
curl api.myip.com
ip route show table ovpnc1
8.8.4.4 via 100.88.0.1 dev vlan2 metric 1
10.8.8.5 dev tun0 proto kernel scope link src 10.8.8.6
10.8.8.1 via 10.8.8.5 dev tun0
100.88.0.1 dev vlan2 proto kernel scope link
8.8.8.8 via 100.88.0.1 dev vlan2 metric 1
127.0.0.1 via 100.88.0.1 dev vlan2
192.168.1.0/24 dev br0 proto kernel scope link src 192.168.1.1
100.88.0.0/16 dev vlan2 proto kernel scope link src 100.88.25.57
127.0.0.0/8 dev lo scope link
default via 10.8.8.5 dev tun0
curl api.myip.com
curl: (28) Failed to connect to api.myip.com port 80 after 150026 ms: Operation timed out
curl api.myip.com
{"ip":"my_VPN_ip","country":"VPN_country","cc":"YY"}
curl api.myip.com
Please advice.
