Skynet No stats shown on WebGUI or CLI
sentinelvdx
I have reset stats and I was wondering how much time it takes for skynet to present something on WebGUI or CLI.
I gave 24hs, but seems something stopped working... because I don't see anything yet.
Ironically, if I try to reset stats via CLI it has zero effect 😅
*edit* until I try the reset a second time.
Well, mine shows the numbers on top now, but no detailed graphs
Run the commands I posted in this thread a while ago, or see if you’ve modified the syslog levels as discussed in the later posts.
Notice and Debug on syslog solved it. Thanks!
