nohup does nor work, am I doing something wrong?
Bamsefar
So I am trying to run a script all the time, it is a simple thing just checking if a mobile is connected to wifi. It works as long as I am online (with putty). Logout and it stops direct.
So I start with:
nohup /bin/sh /jffs/scripts/CheckIfHome2 &
Am I doing something wrong here or is nohup broken?
I'm using AC3200 with rMerlin 378.55.
nohup didn't work for me either. The Entware-ng repository has an app called 'screen'. Setup Entware-ng, then:
opkg update
opkg install screen
Running Screen
Then, to use it, type...
screen sh
It will open another terminal instance. You can now start a process you want to be able to leave running and reconnect to later. For example, downloading something with get_iplayer.
Detach
To detach this terminal session, press
CTRL + A release, and then press D
Then you are back in the original terminal screen with the other one running detached in the background.
List all Instances
You can list all open screen instances and their status by typing…
screen -list
Reconnect
...and you can reconnect to an instance with...
screen -r
SOURCE: http://raspi.tv/2012/using-screen-with-raspberry-pi-to-avoid-leaving-ssh-sessions-open
screen is a good workaround, but nohup seems to be broken/missing in the default busybox implementation.
Alt approach would be to install the bash shell from entware, and then nohup should work fine...
nohup isn't working for me either -- RT-AC68U 380.63
I think it used to work about a year ago, but needed it again this week and it basically kills my process when I logout. I don't want to install opt ware or entware -- is there an alternative ?
I suppose one could get really weird and wrap the script in a loop...
while true; do thescript.sh; done
Just loose the &, otherwise this would be kind of a perpetual "machine" ...
instead of a script that runs continuously, set it to run every minute in the router's crontab.
use cru for that.
ramon@ac66u:/tmp/home/root# cru --help
Cron Utility
add:    cru a <unique id> <"min hour day month week command">
delete: cru d <unique id>
list:   cru l
now you can let your script run and exit, and check the exit status/code.
this will allow you to take actions based on the failure/success of your script.
The nohup seems doesn't work but these way could do it:
Using this command in computer, no ssh login and my_custom_script.sh keep running in background:
Bash:
ssh admin@192.168.1.1 "/jffs/my_custom_script.sh &"
Tested on Merlin 386.2_4
btw: this command can write log into webUI
Bash:
logger -c -p user.info "my custom text"
