The_Immortal
Hi there!
Guys, I'm looking for a strange solution so I wanna ask you to try to be outside the box.
Is there a router which will be capable of downloading and uploading torrent traffic on it at speed like 200/200 Mbit/sec via Transmission (or thru another torrent-router-ready client)? And during that torrent load this router should provide some surfing by LAN/Wi-Fi - so it means its CPU should not be overloaded too much at this time.
I'm going to connect a bay HDD dock (like ORICO 6629S3) to that router via USB 3.0 as file storage.
Is there such router?
Yup, I'm acutely aware of that the given task are not designed for routers in and of itself, and I have to probably take a look into NAS for doing this job but I wanna find a router - it is a challenge!
So till now I've been offered with 3 routers:
- Linksys WRT1900ACS (with installed OpenWRT on it): ARM v7 Cortex-A9 Marvell 88F6820 2 cores 1.6GHz, RAM 512MB, FLASH 128MB;
- ASUS RT-AC86U: ARM v8 Cortex-A53 Broadcom BCM4906 2 cores 1.8GHz, RAM 512MB, FLASH 256MB;
- Netgear R7900P / R8000P: ARM v8 Cortex-A53 Broadcom BCM4906 2 cores 1.8GHz, RAM 512MB, FLASH 128MB.
Actually they were proposed not by their owners - accodring to opinions of some people those routers theoretically can do this job without overloading its CPU. I haven't found any reviews to prove or disprove it.
What do you think about it? Is such router nonexistent in real?
Thank you!
Thank you!
