Moogle Stiltzkin
hiyaz. This my first time with a NAS, QNAP and raid Embarassed
Could someone explain more about Raid 5.
I read that you should install 4 hard drives under raid 5. Then the 5th drive can still be inside and used as a spare ? How do you configure this in the options ? What format extension should my drive be formated to ?
(My qnap 509 is only arriving next week ).
What i need from the raid setup is data redundancy incase my hard drives fail and i need to recover my data. Any ideas what setup i should do ? Or should i not use raid and just use JBOD ? Shocked
I am also having trouble deciding what hard drive to use. The hard drives i am planning to install are either 1tb or 1.5tb ( most probably the 1tb since the current 1.5tb is defective.)
Does QNAP 509 support enterprise server hard drives meant and certified for 24/7 operational continuous usage ? does it matter ? If so which would you recommend ?
I was looking at the Seagate Barracuda ES.2 ST31000340NS but read later that there was something defective about it Shocked
Anyway i will be using the QNAP for torrenting 24/7, as well as a web/forum server.
