I would like to have more range than my current setup.
I have an n300 router where my cable modem is and wired a TP-Link Archer c7 on another level. On my patio I have mediocre to no signal from both. My thought replace the N300 with Archer C7 and buy a new router for the other level. Most of my use is on the other level and typically includes 2 iphones,2 ipads, 2 laptops, firstick, roku.
I want a reliable, set it and forget it system. I was thinking of the Asus RT-AC68U ($140). But then I found a couple of sites that recommended the d-link DIR-882 ($118) for best range. I stopped by the store and the also had a tp-link ac2600 ($99).
I am now totally confused. Your help is appreciated.
