Using an R7000 and fairly new to setting up on the server side. I am able to connect, have internet access and some access to my local network. I have a wired connection to a desktop w/attached drive which is shared and has a static IP. I can not seem to be able to access that computer; can't ping it's address either. I can though ping some, not all, of the other computers on the network. Layout is: router 192.168.5.x, vpn 10.10.8.0 any help would be much appreciated.
Server config - (from /tmp/etc/openvpn/server1)
daemon
topology subnet
server 10.10.8.0 255.255.255.0
proto udp
dev tun21
cipher aes-256-cbc
auth sha512
comp-lzo adaptive
keepalive 15 60
verb 3
push "route 192.168.5.0 255.255.255.0 vpn_gateway 500"
push 'dhcp-option DNS 192.168.5.1"
push "redirect-gateway def1"
client-config-dir ccd
client-to-client
tls-auth static.key
ca ca.crt
cert server.key
status-version 2
status status 5
Client config
client
dev tun
proto udp
remote [redacted] 1194
float
cipher aes-256-cbc
auth sha512
comp-lzo adaptive
keepalive 15 60
remote-cert-tls server
resolv-retry infinite
nobind
daemon
topology subnet
proto udp
dev tun21
cipher aes-256-cbc
auth sha512
comp-lzo adaptive
keepalive 15 60
verb 3
client-to-client
tls-auth static.key
ca ca.crt
cert server.key
status-version 2
status status 5
Client config
client
dev tun
proto udp
float
cipher aes-256-cbc
auth sha512
comp-lzo adaptive
keepalive 15 60
nobind
