Not able to ping to WAN
CntrlAltDel
Hi everyone,
I recently switched from OPNsense back to Asus Merlin, and the only issue I'm facing is getting ICMP (ping) to work from external sources to my WAN. I’ve enabled the "Respond ICMP Echo (ping) Request from WAN" option, but it’s still not working. I even tried disabling the firewall entirely, but I still can’t ping from external sources.
I did a fresh install of version 386.14 on my RT-AC88U. It can't be that my ISP is blocking ICMP, as everything worked fine with my OPNsense setup yesterday. I feel like I might be missing something simple—any advice would be greatly appreciated!
Are you referencing your public IP on the WAN explicitly or using the DDNS domain name? If the latter, perhaps the public IP changed when you installed Merlin but you didn't configure DDNS to update your domain name (just a guess).
Initially, I had a DDNS domain name configured, but I switched to using the public IP directly for testing, thinking it would give more accurate results. Still no luck.
I'm not sure if I’m checking the system log correctly—I’ve set the firewall to log all dropped packets, but nothing seems to be appearing in the auto-update stream in the system log.
Are you running a VPN client on the router at the same time? If the router itself is bound to the VPN client (as opposed to just other devices on the LAN), which would be the case, for example, if you configured "Redirect internet traffic through tunnel" on the OpenVPN client w/ "Yes(all)", you can NOT remotely access the router over the WAN at the same time.
No, in order to troubleshoot why inbound ICMPs specifically are getting blocked I kept my config as simple as possible to ensure nothing else may be causing this behaviour.
Issue the following iptables command to zero the packet counts on the input chain.
iptables -Z INPUT
Then attempt to ping the router from the internet side of the WAN. Then dump the firewall to see if the icmp rule is there, and whether the packets count (pkts) > 0.
iptables -vnL INPUT
