First, The connections- Wired from the Modem to a Cisco RVS54000, which has one wired workstation computer and a wired, Wireless EnGenius ESR9850; the ESR9850 is setup as a AP Router with WDS enable.
A second Wireless EnGenius ESR9850 is setup as a Repeater on the second floor of the house with two wired computers attached.
All the needed function are set for both EnGenius, (Router setup)firewall, WPA2 pre-shared key and WPA2(AES), channel set-not in auto and bandwidth at max, short Preamble, CTS protection, etc.
The problem is while using a wireless computer "only" to access the repeater to connect to the internet, the connection does not initiate at times and or stay connected.
Thanks for your help
Hap
Hap
