realmikeazn
Hi all,
I wanted to share my experience with the GT-AXE11000 and firmware compatibility when using IP Passthrough with an ISP-provided BGW210-700 device.
Firmware Tested:
GT-AXE11000_3004_388.8_4.zip
Download Link
Result: Failed with ISP DHCP issues.
GT-AXE11000_3004_388.8_2.zip
Download Link
Result: Same issue—unable to establish a stable DHCP connection.
Firmware That Works:
GT-AXE11000_388.2_4.zip
Download Link
SHA1: 8a508bca506b0c94d41e39529319b9a14ea6d462
MD5: 00cceaf39ab62698bf334838c376dad5
This version worked perfectly in IP Passthrough mode without any DHCP failures.
Summary:
If you're using the GT-AXE11000 router with an ISP-provided BGW210-700 and experiencing DHCP failures, I recommend sticking to the GT-AXE11000_388.2_4.zip firmware version.
Hope this helps someone facing a similar issue. Let me know if you have any questions or insights!
— Mike
Firmware Tested:
Download Link
Download Link
Download Link
Summary:
— Mike
