nslookup of local names never works
vrapp
On the router's LAN/DHCP Server page, I have specified RT-N66U's Domain Name as familylan. On a workstation I run nslookup mypc or nslookup mypc.familylan (with the dns server being the router and mypc being the name of an existing workstation that appears on "network map" page), and the response is always "Non-existent domain". Isn't it supposed to resolve?
I think you mentioned you do, but under LAN>>DHCP do you have the dns server set to the ip address of the router (presumably 192.168.1.1)?
If you haven't already, reboot the router and computers...
do you have the dns server set to the ip address of the router?
I do, or I even specify the server to use in the command itself:
C:\>nslookup
1.1.168.192.in-addr.arpa
primary name server = localhost
responsible mail addr = nobody.invalid
serial = 1
refresh = 600 (10 mins)
retry = 1200 (20 mins)
expire = 604800 (7 days)
default TTL = 10800 (3 hours)
Default Server: UnKnown
Address: 192.168.1.1
C:\>server 192.168.1.1
serial = 1
> vadim.familylan
Server: UnKnown
*** UnKnown can't find vadim.familylan: Non-existent domain
Router's page Network Tools/Network Analysis/Nslookup can't resolve it either.
Set it up properly works fine for me
C:\>nslookup
Default Server: odyssey.shonk.org
Address: 192.168.0.254
> server 192.168.0.1
Default Server: aurora.shonk.org
Address: 192.168.0.1
> p5p43td
Address: 192.168.0.30
> vostro
Address: 192.168.0.31
> vostro.shonk.org
> www.shonk.org
Non-authoritative answer:
Address: 184.168.192.21
Aliases: www.shonk.org
