NUT UPS Support?
Michael Schemmer
Hi there,
@RMerlin, thanks for all your hard work on this firmware over the past few years. I'm running a AC88U with 384.5-beta1 and pretty happy with the performance.
I see that the latest branch includes USB-HID support and specifically supports APC UPS'. Would it be possible to add the NUT drivers aswell, since they support quite a huge variety of UPS'
Check out https://networkupstools.org/index.html for info on the driver
If its too much of a mission could you point me in the right direction to create my own build or anyone who has done something along these lines?
Thanks again!
I was willing to enable the HID drivers because they are part of the kernel, and fairly small. However third party drivers are beyond the scope of this project. See if Entware might have them available.
Ok thanks alot! Will look into it. Keep up the brilliant work!
