dragunov84
Running Nvidia Shield 5.2 (5.1 same issue) and using an Asus RT-AC87U router on the latest firmware (also tried latest merlin firmware) and the Shield is causing the CPU to jump to 100% on the Asus router.
The shield does not have to be doing anything but I can prove it is the problem but removing the ethernet cable, once removed the CPU drops to 2% and the web interface is usable. Reconnecting the ethernet causes the CPU to jump back to 100%. This causes issues with the entire network as the router cannot respond to any request.
Anyone else having similar problems?
