NVRAM save before reboot
Is it a quick way to save my wifi schedule?
It disappears every time I reboot.
A known issue, has happened to me with both factory & Merlin firmware.
Maybe Asus will fix it one day.
I don't have the same hardware/firmware version as you, but assuming the NVRAM variables haven't changed this should work:
Save your current Wi-Fi schedules:
nvram show | grep -E "wl._timesched|wl._radio_date_x|wl._radio_time_x|wl._radio_time2_x" > /jffs/scripts/wifisched.nvram
Now create a /jffs/scripts/services-start script as follows (or append it to your existing script):
#!/bin/sh
# Create file with "nvram show | grep -E "wl._timesched|wl._radio_date_x|wl._radio_time_x|wl._radio_time2_x" > /jffs/scripts/wifisched.nvram"
while read line
do
    nvram set $line
done < /jffs/scripts/wifisched.nvram
nvram commit
#!/bin/sh
while read line
do
    nvram set $line
nvram commit
Colin,
How will this script be executed automatically at reboot?
There are scripts that run automatically (if they exist) when certain events occur.
https://github.com/RMerl/asuswrt-merlin/wiki/User-scripts
It doesn't work.
These are the variables' values I get in the wifisched.nvram file:
It looks to me that they don't cover the entire array for all the hours and days of the week
Can you post a screen shot of your schedule as seen in the GUI. I think I'm misunderstanding what you're trying to do.
Ah I see. We're talking about different things. I thought you were talking about the Wireless Scheduler under Wireless > Professional that looks like this:
What router page are you seeing that schedule? It's possible that my firmware doesn't have it.
The ac86u is on a new platform - the wifi scheduler is also under wireless - professional but it looks like I showed you
Ah, OK. Sorry, I can't help you as I don't know what NVRAM variables are used now. I've had a quick look at the source code for 384 but it's not immediately obvious what the variables are. Maybe someone else knows.
It doesn't work.
Try these nvram variables
nvram show 2> /dev/null | grep MULTI
