Nvram setting to disable ssh access from wan
Goobi
Running 380.64 on 68U. For some reason, the "Allow SSH access from WAN" setting under Administration-System does not have either the Yes or No radio buttons selected. If I select No and then click apply it never gets set.
For now, I was wondering if there is a nvram command to disable (set to no) from the ssh command line?
Thanks in advance.
Sounds like you might have corrupt NVRAM and might want to do a factory reset.
