M
MvW
Guest
I have an odd error in syslog, which I've never seen before and the forum search has only little results, and none of the situations others describe are applicable. Nothing has changed, just out of the blue I see:
As it happened in previous versions I can't imagine it has to with beta 3, I've made no changes to the network or the routers settings today, I only just logged in to check for updates in amtm and noticed these in uiScribe. I don't use Wireguard or Cloudflare Warp (as suggested cause in the search results). I have two OpenVPN clients connect to ProtonVPN in two different countries, I use NextDNS CLI for DNS resolution and the rest is in my signature. I have an inactive installation of Diversion, just for it's mailing functionality. Any clues as to what could be causing this strange error?
I've never seen it before.
Best regards,
Marco
Apr 1 20:22:54 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when adding flow net_p=ffffffc0087f79a8 dir=0 old_key=0x2000343a new_key=0x20003448
Apr 1 20:22:54 RT-AC86U kernel: [0m
Apr 1 20:22:54 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when adding flow net_p=ffffffc00bc217d8 dir=0 old_key=0x2000343d new_key=0x20003449
Apr 1 20:24:28 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=ffffffc00bc217d8
Apr 1 20:24:28 RT-AC86U kernel: [0m
Apr 1 20:26:51 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=ffffffc0087f79a8
Apr 1 20:26:51 RT-AC86U kernel: [0m
Apr 1 20:29:51 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when adding flow net_p=ffffffc0087f79a8 dir=0 old_key=0x2000348a new_key=0x20003497
Apr 1 20:29:51 RT-AC86U kernel: [0m
Apr 1 20:29:58 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when adding flow net_p=ffffffc00bc217d8 dir=0 old_key=0x20003490 new_key=0x20003499
Apr 1 20:29:58 RT-AC86U kernel: [0m
Apr 1 20:33:16 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=ffffffc0087f79a8
Apr 1 20:33:16 RT-AC86U kernel: [0m
Apr 1 20:33:16 RT-AC86U kernel: [0;33;41mBLOG ERROR blog_request :blog_key corruption when deleting flowfor net_p=ffffffc00bc217d8
Best regards,
Marco
