spdMerlin Odd result upload speed after ISP change VLAN AX86U
Plompie
Hi All, been a while since last been here as everything was running super smooth for years.
Since a few weeks I’ve switched ISP’s. Both at a 1 Gbps subscription and still over the same fiber but other service provider. This new provider (Odido Netherlands, former T-mobile) uses a VLAN for internet from the ONT (VLAN 300) which I added via the IPTV menu of my AX86U. The Speedtest on my wired PC still shows abt the same results of ~930 Mbps up and down. However SpdMerlin shows odd results for the upload as per below. As the provider confirmed the line is fine and speed tests on a wired PC confirm same, I wonder why SpdMerlin shows such odd results.
Could this have to do with the VLAN as this is the only setting I changed?
The switch happed on the 23rd:
Edit; typo
As an aside, you've performed the test, just as all the tech junkies are on their Xmas jollies. Might want to see what it's like when life has returned to normal!
Hi! yes, that's what I thought as well but with a wired laptop the results were fine all along (~940 Mbps). Also this week the results of SpdMerlin scrip remains fluctuating.
The script worked fine on this router with my old ISP, so must be the new ISP. But with a wired laptop the speedtests are consistently fine so cannot be the new ISP.
It's not a major thing as the connection works fine, but just puzzled by these odd results.
