Doug P
I’m new here and certainly no networking expert, so please be gentle! ;-)
I have an oddball issue and I hope the experts here and steer me in the right direction OR tell me to drop it as not do-able.
I live on a sailboat. Virtually all Marinas I stay in have some form of public WiFi and most of the time it’s more than adequate. And since we are often surrounded by taller power vessels and since our sailboat sits low in the water, I setup a typical Boat/RV type system to “bring” the marina signal below.
GEAR:
I have a MikroTik Groove 52AC mounted about 20’ above the waterline. This router is connected to the Marina's public WiFi in Router Mode.
The output of this 52AC comes below over Cat6 where it is connected to the WAN port of my TrendNet TEW-812DRU router. I also have my NMEA2000 backbone connected via WiFi so I can see data from my Raymarine system’s sensors/devices.
This all works great when we have decent marina signal/bandwidth we have solid WiFi on the boat.
When I occasionally leave the boat, I can access my laptop (If left onboard) fine with Team Viewer, I can also access two security cameras (with android apps) easily from anywhere because they are P2P cameras.
My problem is that I need to access my boat’s network from outside the Marina when we are away from the boat so I can check the data being sent by the various sensors.
When we had cable internet at our house, I had no problems doing this by DDNS and port forwarding, but now no matter what I try, I cannot get thru to my network from outside.
Can this be done? What do I need to do to make this work?
Thank you very much!
Doug
GEAR:
Doug
