Veldkornet
ASUS DSL-AC68U Firmware version 3.0.0.4.378_9168 (This product supports both Annex A and Annex B)
Release Notes:
-Remove mDNSNetMonitor related debug logs.
-Fixed 802.1Q enabled with VLAN ID 0 setting cannot take effect issue, 802.1Q setting reverted back to disabled.
Global Download Link
ASUS Support Download Page
As well as the below of course which was from the firmware just a day or two before in 3.0.0.4.378_9166...
ASUS DSL-AC68U Firmware version 3.0.0.4.378_9166 (This product supports both Annex A and Annex B)
New features:
- Bandwidth Limiter in Adaptive QoS > QoS. Allow administrator to easily limit specific client's upload/ download bandwidth.
- Now Quick Internet Setup supports ADSL WAN (ATM) VLAN ID setup, specifically for Germany/ Thailand ISP.
- Quick Internet Setup now supports IPTV setting, specifically for UK/ Turkey/ Russia ISP.
- Independent MAC filter for main wireless network and guest network. Administrator can set white list for main wireless network to only allow trusted client connect to main wireless network and share network to guests with guest network.
- Modify the network map client status. When click the client icon, administrator can bind IP, change host name, change icon, block Internet access or set time scheduling.
- Time scheduling, Web & App filter, Wireless MAC filter client drop down menu now can show offline devices.
- Add 3G/4G USB modem APN auto detection feature. In most cases, firmware can automatically find the ISP profile and establish link when 3G/4G dongle inserted to router.
- Add Android phone in USB modem/ USB Tethering > Select USB device.
- Add Smart Sync Dropbox, ftp, samba client support.
- Show current WiFi control channel while value is Auto.
- [AiCloud] Show image EXIF info on image player.
- [AiCloud] Auto rotate image on image player.
- [AiCloud] Files can be moved and copied.
- [AiCloud] Images can be uploaded to Picasa or Twitter.
- [AiCloud] Share link can be posted on Twitter, Plurk, Weibo and QQ in AiCloud.
- [AiCloud] Add import certification.
DSL:
- DSL firmware updated - v1.0.3.2.
- DSL driver updated - v5.5.1.135.
- Fixed ADSL2/2+ stability issue with certain DSLAM.
- Fixed G.dmt Bitswap abnormal issue with certain DSLAM.
- Fixed possible ADSL2/2+ Bitswap gets triggered incorrectly/ frequently issue.
- Fixed possible Bitswap bug caused SNRM to drop gradually and leads to interruption.
- Now when VDSL Annex type is Region B(Europe) but US0 type is Annex A, DSL Log would display as Annex A instead of Annex B(for this case, Annex Mode should be configured as Annex A/I/J/L/M or Annex A).
- [DSL Log] Add TCM(Trellis Coded Modulation), downstream and upstream interleave depth information.
- [DSL Log] Show G.inp upstream/downstream info.
- [DSL Log] Fine tune dsl log page.
- [DSL Log] Show VDSL current profile in DSL Log and feedback form.
- [DSL Setting] Enable G.Vector(G.993.5) by default.
- [DSL Setting] Add 12a multi mode and 8a multi mode for VDSL.
- [DSL Setting] Remove Rx AGC Gain Adjustment(ADSL/ VDSL) DLA auto configuration.
- [QIS] QIS auto detection list updated.
- ADSL WAN (ATM) QIS manual setting list updated, includes more settings for Argentina, Armenia, Australia, Azerbaijan, Belgium, Brazil, Brunei Darussal, Cambodia, Canada, Colombia, Dominican Republic, Colombia, Egypt, France, Germany, Greece, Hungary, Iceland, India, Indonesia, Iran, Ireland, Italy, Kazakhstan, Luxembourg, Malaysia, Mexico, Netherlands, New Zealand, Norway, Palestinian Authority, Peru, Poland, Portugal, Saudi Arabia, Singapore, Spain, Sweden, Thailand, Tunisia, United Kingdom, Ukraine, USA, Venezuela, Vietnam.
- VDSL WAN (PTM) QIS manual setting list updated, includes more settings for Argentina, Brazil, Canada, Finland, France, Germany, Poland, Qatar, Spain, United Kingdom, Vietnam.
Security fixes:
- Update OpenSSL library to 1.0.2d.
- Update Trend Micro security engine.
- Fixed CVE-2015-6949 buffer overflow issue.
- Fixed Web server Accept-Language buffer overflow issue.
- Fixed Web server URL handler buffer overflow issue.
- Enhanced router login password and wireless password(WPA2) strength check method against brute-force attack.
- Prevent administrator to set too easy to guess login and wireless password in order to avoid brute-force attack.
Modifications:
- [AiCloud] Use https url while playing music in AiCloud.
- [AiCloud] Change to use html5 player on Firefox instead of flash player.
- Adjust Adaptive QoS UI, now easier to set top priority for gaming, media streaming or web surfing.
- Enhance animated effect for progress bar of CPU/RAM and Bandwidth Monitor.
- Extend the OpenVPN key & certification field length to 4096 bits key.
- Add 3G/4G log option in Feedback.
- Media Server, minidlna updated.
3G/LTE:
- Support Huawei E3372, E303u-1, E3531s-6 dongles.
Bug fixes:
- Fixed VDAL WAN (PTM) Automatic IP connection type with no VLAN ID setting, WiFi both bands low throughput issue. Workaround solution adopted, configure with VLAN ID 0(reset to default a must).
- Fixed cloud sync issues between router and ASUS webstorage.
- Fixed share link related issue to Android devices.
- Fixed browser compatibility issues.
- Fixed GUI related issues.
- Fixed parental control-> time scheduling related issue.
- Fixed adaptive QoS device priority label dragging issue.
- Fixed UI issue when selected French.
- Fixed OpenVPN connection status display error.
- Fixed OpenVPN server account setting issue.
- Fixed the settings of Disk Health Scanner cannot be saved.
- Fixed traffic monitor data error.
