Official RT-N66U Firmware 3.0.0.4_378_8258
Is this to be officially released? I don't see it on the ASUS support site here in the US.
I don't have an update when is this going to be posted on Support site.
Replied through Tapatalk
Because I received it directly from ASUS rep. instead of the ASUS site, I consider it Beta.
It can say sometimes Japan Only, but that doesn't affect at all, because there aren't different versions of N66U's, trust me.
I'm not from Japan and my routers were not bought in Japan and I do test with the "Japan Only" firmware.
Probably is related to country regulations, about radios, etc. That then later check and release ensuring it will not give them prblems with that country regulatioms
any update for RT-N56U? :( latest build available is 6065
Nope, sorry. I didn't receive one.
Is this also compatible with the W and R versions? Also how is 8258 working for you as I see you have it installed on 2 routers? Thank you.
I went ahead and installed it on the U and W versions and both work fine. Basic internet, streaming and gaming work great on both. Thanks.
Hi, Is this version again 'Japan only' (as the two last updates) ? ;)
Joe :cool:
For the 7410 "Japan Only" version see the bug fixes:
Bug fixes
- Fixed network map UI issue when selected French.
Why using French in Japan ??
"Japan only" seems to me a non-issue.
